cant get tv splitter to work...
narendar
I just bought a brand new tv splitter/amplifier (16 Way Diglink Amplifier c/w 4G Filter, 16 Way Diglink Amplifier c/w 4G Filter) but I cant get any signal from any of the outputs. I've connected the RF2 output from my skybox to the UHF input on the amp and then connected a TV directly to one of the 16 ouputs (sevaral of them separately, just to be sure), but nothing. When I connect the RF2 ouptut directly in to the TV, it works ok, so definitely no problem with that cable. There is a power light on the amp so it's plugged in ok, but I can only think that there is some problem with the amp itself. It's possible I may be missing something else but would appreciate any suggestions before I take it back to the shop.
Thanks!
Nick P.
outoftheknow
Thanks!
Nick P.
Have you read the note on the installation instructions?
https://www.tlc-direct.co.uk/Technical/DataSheets/Labgear/LDL212_LDL216_Instructions.pdf
If yes and you have done as required, then it might be faulty.
narendar
Yes! That was exactly the reason! Also, some of the plug connections weren't great so I changed them all, but the changing the output frequency from the default of 68 to 59 did the job. Don't know how I missed that in the instructions. Thanks a lot!
Nick.
outoftheknow
You're welcome. The splitter can't even 'see' the frequency of the default Sky box RF output, let alone amplify and split it. It is surprising the instructions don't have that bit a little more upfront. The frequencies it handles are clear but what that means in channel terms isn't really quite so clear. :)
