Can't get SID files onto xbox
Coggss
Ok, this sounded really easy (and I am sure it is).
I am unable to get SID (splinter cell and launcher) files onto xbox. I have tried putting them onto memory card with pc using xploder, but when I drag them on it says card full. I have erased memory card on xbox and it says it has 498 blocks free (something like that).
So I have tried to ftp them to my chipped xbox, bit I must be putting them into the wrong place, cos when I go into the memory saves in MS Dash, they are not there.
I sure this is really, really, easy, but I can't suss it (been trying since lunchtime).
Any help would be much appreciated, cheers. :lease:
Coggss
Ok, I have now managed to get them onto my chipped box, but I don't have the option to copy them onto the memory card, only delete option ?????
blisteringblue
When looking at the files on xbox press right with your left thumbstick/pad, they should then be hilighted slightly and this time when you select them you should also see the copy option.
Coggss
Sorted, managed to find a copy of 'AC'. That worked with memory card through pc - usb -mem. card.
Thanks anyway.
