Can't get S-Video input on Panasonic TH42PV500
Discussion in 'Plasma TVs' started by lasitha, Jun 12, 2005.
  1. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    When I try to connect my DVD player using a S-Video -> SCART cable, I get a very distorted, almost black & white picture (works fine when using a composite -> SCART cable). I tried using AV1, AV2 and AV4 inputs. I then tried with a S-Video-> S-Video cable on AV3 and got no picture at all. Then I tried connecting my camcorder using a S-Video-> S-Video cable on AV3. Again no picture at all.
    Any ideas why this is?. Am I using a wrong kind of S-Video cable?.
    Thanks for any info/suggestions.
    Lasitha
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Have you set the scart to output S-video? They don't do it by default. And is there a good reason why you want to? RGB would be better, and it's only a press of a button and a fully wired scart away.
  3. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    How do I set the Scart to output S-video?.
    My DVD player only has two outputs (S-Video and componet). The S-Video output worked fine on an old Sony CRT TV.
  4. chedmaster
    chedmaster
    Jan 29, 2005
    2,654
    68
    +28
    have you set the scart input to s video as opposed to composite/rgb (on the tv)
  5. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    Sorry, my fault. I didn't realise that you have to press the AV<x> button twice to get the S-Video input.
    Works perfectly now.
    Lasitha
  6. Member 55145
    Member 55145
    Jan 18, 2005
    12,071
    +3,489
    umm if your dvd player has component hook it up via that, it will be ALOT better, oh unless you have something already taking up component?
  7. lasitha
    lasitha
    Jan 26, 2004
    270
    London
    +3
    No component output, only composite and s-video.
