Can't get on live - IP address failing
  • Thread starter Deleted member 380232
  • Start date
D
Major peoblems getting online. Here's the situation
Have a Netgear router on Virgin Media modem. Am using homeplugs which take the broadband from the router to my kids bedroom. The other homeplug then plugs straight into the xbox in the bedroom.
When I first set this up it worked flawlessly first time and has been working for the last 2 months fine. All of a sudden - can't connect. IP address failed. It is set to automatic and is showing an IP address of 169.254.228.189 which is mince.
I have tried entering manual settings but still the same error comes up.
I also have an xbox downstairs plugging directly to the router and it works fine so it's not the router or my broadband
Any help? Please?
I have tried xboxlivetheguide.com and xbox.com help - no joy :mad:
D
Should also say I have reset the homeplugs and think I have them setup correctly
Codehead
169.254.*.* is an APIPA address. That is it's dynamically created when DHCP is used and no server can be found. It's common on Win2K and up.
I take it it's a computer that's having the issue? Tried a reboot of the compy?
If that doesn't work, your DHCP server (probably the router in your setup) isn't giving an address out to the computer.
D
No - it's my kids xbox which has the issue. It's at the other end of the homeplug
My computer is a Mac and is wireless - it's working fine. Mac and router have all been rebooted
Codehead
I'm soooo sorry mate, I didn't know. :(
:rotfl::rotfl::rotfl:
Anyway, I didn't know the 360 used APIPA, but it's definatetly given itself an address 'cos it's bored of waiting for the router to provide one. Sounds like the home plugs might be at fault.
Can you take another machine up there? A laptop maybe? To test the network?
D
Cheers - I could drag the mac through I suppose - will give that a go
Surely it's not the xbox! :eek:
D
The mac doesn't work either - same problem with IP addresses
So somehow the router isn't getting through the homeplugs - this is annoying - think I'll just buy a wireless adaptor instead :suicide:
Codehead
I should say that I broke your net as punishment for Chuckrolling the GoW forum. :devil:
I've got no experience with homeplugs, but it does look like the router and xbox aren't seeing each other. Is there any way of checking the homeplug config?
D
yeah I think it is the hps
have reset the config 2 or 3 times - still not working - damnit
virtual22
Have you tried taking the homeplugs downstairs next to each other to see if this helps, then other sockets round the house mate? I have heard of these things failing because mobile phone charges are plugged in, surge protectors in use, ring main issues, all sorts.
D
Now tried different sockets - same problem - really starting to annoy me as it was working fine the other day and I haven't touched anything
I now have a sad little 7 yr old who can't pwn n00bs on Halo :(
Morphies
You say you have multiple homeplugs kicking around?
Try a different one on that socket.
If that works, you know your plug has gone down.
You could also specifying an IP within the 360 dashboard, this will cut out the DHCP side of things.
D
No just the 2 I have
I tried the manual settings - they didn't work either
