Can't get Nicam Stereo Sound on Sky Digital Please Help!
Discussion in 'Sky Digital TV Forum' started by mcoupeloon, Jul 23, 2002.
  1. mcoupeloon
    mcoupeloon
    Jul 1, 2002
    29
    cardiff
    Needed a way of getting Sky through my Sony HS1 projector so have just bought a new Sony vcr with nicam stereo.
    I am using a normal video lead with magic eye for input.
    When the video auto tunes for channels all the normal ones play with nicam, but the one channel for sky is in mono!
    Any ideas?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    SKY do not use NICAM.
    Never unless you have NO choice use the RF lead for viewing SKY, you should always use a scart connection which carries the stereo sound or the s-video (If you have it) with the twin phonos carrying stereo to an amplifier.
    I am assuming the "video lead" you mention is the RF cable:)
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    The Sky digibox RF output is mono.
    Try connecting a scart lead to the vcr from the digibox, then select the appropriate AV on the vcr instead of the RF channel, this will loop stereo through. Of course, Sky does not use Nicam, so don't expect a Nicam indicator to light.
  4. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    +32
    Starburst posted while I was eating a steak and mushroom pie.:)
  5. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    :p
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    BTW you do need to connect with scart, the phono outputs are mono on most STB's. Why? Why does superman wear his pants outside his trousers?
