Can't get new card to work in Sky+....
Discussion in 'Sky Digital TV Forum' started by Stevie G, Apr 18, 2003.
  1. Stevie G
    Stevie G
    May 2, 2002
    637
    +33
    Got my replacement card from Sky this morning. I do what it says; switch on with old card, removed card, wait 5 secs then put in new card, but it keeps saying there is a fault with the card, then just hangs on searching for channels (aat which point I have to turn it off at the mains and insert the old card).
    Any ideas?
    I've tried the Sky number but it's all bloody automated, and I know that the picture may be fuzzy in bad weather.....!
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    I realise that this won't help you with your immediate problem, but here's a tip for automated phone systems... don't press any buttons at all, if you wait a while it'll give up asking and put you through to a real person!
    They all need to have such a fallback system as there are still some people without touchtone phones around despite nearly all UK exchanges being fully digital :smoke:
  3. DaveP
    DaveP
    You say "replacement" card, does this mean you had one previously? Is it the new New card that people are getting? If so I thought that the Sky+ wasn't getting issued with new cards.
    Anyway, you may wish to try a new install from the service menu. You will need to have the box connected to a 'phone line.
    DaveP
  4. Stevie G
    Stevie G
    May 2, 2002
    637
    +33
    Yes, it's a replacement, as they say the old one will expire, and it is Sky +. I'll try ringing them again (I'd forgot about it!)
    Thanks for the tip btw, rct.....it worked with getting through to Singlepoint!
  5. paulefox
    paulefox
    Feb 8, 2003
    1,343
    Bury St Edmunds
    +44
    I received a card and was not sure wheter it was for my sky+ or for the other received so I rang them up. They said that no cards have been issued for sky+ yet and the card was for the normal decoder so if you have two systems that will be the answer
  6. Stevie G
    Stevie G
    May 2, 2002
    637
    +33
    Ah, ok. I have a second box that I don't currently use. They did send me a second card for it, but I never used it, so it must be a replacement for that.
  7. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    You're welcome ! Those "4u" people can be fun can't they? :suicide:
  8. bobbles
    bobbles
    it should say on the peice of paper the card was stuck to, this is to replace card number ..... I was puzzled which card to swap at first but it was the old box.
