Can't get my remote to work
Discussion in 'Satellite TV, Sky TV & FreeSat' started by swadd, Feb 3, 2009.
  1. swadd
    swadd
    Feb 3, 2009
    4
    I have just had my sky HD box replaced and now for some reason my sky plus remote won't contol the HD box.
    I have tried the sky plus remote via the magic eye in the bedroom and direct to the HD box but neither will work.
    This worked fine before the HD box was replaced.
    Can someone please help.
  2. bluesat
    bluesat
    New batteries ? maybe..... otherwise i'm stuck on this one...
    sorry
  3. swadd
    swadd
    Feb 3, 2009
    4
    tried new batteries and no difference
  4. SkyVanMan
    SkyVanMan
    Oct 13, 2008
    160
    +19
    Try pressing tv then red and select together and hold them down untill you get 2 blinks, press 1, then select.
  5. dmaidmen
    dmaidmen
    Nov 25, 2006
    462
    +73
    swadd
    What exactly happens when point the remote at the box and press the Sky button and then try and change channel for instance. Does the box flash indicating that it is receiving the signal from the remote?
    I assume the new box is alive? i.e. you can control it from the buttons on top?
    If you can control the box from the buttons on top but not the remote then I would suggest connectring the magic eye directly to RF2 and seeing if that works. I just sent a box back for having this exact problem. Hope they haven't sent it out already :rolleyes:
    Duncan
  6. markmaslin
    markmaslin
    Apr 5, 2006
    60
    Thatcham
    +10
    Thats weird cos my remote control has packed up today aswell completly dead
  7. swadd
    swadd
    Feb 3, 2009
    4
    I have tried to all but to nothing works.
    My Sky HD remote works fine so its not the box I think.
    My sky+ remote will control the tv ie volume, on/off etc but will not do anything with the Sky HD box.
    The red light on the front of the HD box doesn't even blink with my std sky+ remote.
    is my remote dead?
  8. bluesat
    bluesat
    Have you updated the software of the HD box ?
    Could be they have changed the infra red frequency....
    Probably not, but you never know with sky...
    Have you another Sky + box you can try your older remote on....
    I take it you want two remotes so you can keep one in each room ?
    Andy
  9. swadd
    swadd
    Feb 3, 2009
    4
    It worked after using blue button & select and then pressing zero.
    Thanks for all your help.
    :thumbsup:
  10. SkyVanMan
    SkyVanMan
    Oct 13, 2008
    160
    +19
    Bugger, ye sorry !
