S
IrishRob said:Havn't tried connecting a V3 to my PC, but have connected up a Motorola V525. IIRC you need to install the software on the CD that comes with the phone. When the software is installed it will then ask you to connect the phone to your pc and it should now be automatically recognised by the pc.
Hope this helps. Apologies if you have tried this already.
nightfly56 said:do you have bluetooth on your pc?? if not you can pick up a bluetooth dongle for about £10/£15 from Argos, install the software and away you go I find it quicker than the cable method, hope you get sorted I know how boring pre-installed ringtones can be
Mick
Chamber said:get rid of it, all phones exept nokia are useless, with nokia u dont have any problems..connect and browse
Chamber said:oh, and by the way, if u buy phone unlocked, brand new, without the contract and that sort of stuff, ur phone wount have any problems in further life..
nightfly56 said:don't be so quick to slag other brands of phone, I and I am sure there are plenty of others out there, have had bad experiences with Nokia phones. I have a Razr V3 and it is an excellent phone, does everything I want it to, I have had problems but Orange sorted them quickly and without fuss.
Nick_UK said:Sorry, but I have to agree on the V3. The V3 is a great looking phone, and it feels very good in the hand, but as a phone it stinks. The battery life is too short (especially with bluetooth) and it goes into "sulk mode" too often, when you have to switch it off & on to make it wake up. If you don't make many outgoing calls, the V3 can be sulking for quite some time before you realise why it hasn't rung for several hours.
After owning a V3 for quite some time, I've now got myself a Sony Ericcson V810i, which is nowhere near as pretty, but is better than the V3 by miles.
