Can't get DTS sound out of Yamaha DSPAX 620
Discussion in 'AV Receivers & Amplifiers' started by PaulW, Jan 7, 2002.
Tags:
  1. PaulW
    PaulW
    I have just set up the Yamaha DSP AX 620 amp with a Panasonic RV20 DVD player, connected by digital optical cable.
    Amp is DTS compatible, DVD is DTS compatible. Dolby Digital is working like a wet dream but I can't for the life of me get DTS sound coming out (e.g. using Gladiator DVD, and choosing DTS from the input mode at the front of the amp I get nothing). .
    Anyone with this amp had a similar problem? :confused:
  2. robocook
    robocook
    Nov 6, 2001
    137
    19
    Sevenoaks, Kent
    have you checked the output from your DVD player's set-up menu
    Set-up option "Digital Audio Output" and check that dts is set to on - judging from the PDF manual off is the "factory preset" - this needs to be changed to bitstream.
  3. mjn
    mjn
    May 24, 2001
    23,499
    Herts, England
    +11,906
    have you set the film to DTS rather than DD in the setup menu??
  4. PaulW
    PaulW
    I know I definitely set up the digital output on the DVD to on, and PCM down conversion to YES (whatever in gods name that means) but I didn't know you could select DTS from within the software. I'll give it a go tonight.
    Isn't DTS just a bag of ****e considering there only appears to be one DVD with DTS compatibility? (gladiator). Prove me wrong - any other decent films with DTS soundtracks....?
  5. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    there lots out there on region 1 lol
    :D
  6. bob007
    bob007
    CHICKEN RUN D.T.S
    Now there's 2 ;)
  7. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Pitch Black Regon 2. Thats 3.
  8. museumsteve
    museumsteve
    Jan 28, 2001
    8,003
    4
    Nth Hampshire
    +1,109
    Rush Hour 2 - that's..err 5 (lost count)
  9. GearHead
    GearHead
    Se7en - thats four.
    (or is that four - thats se7en. ouch)
  10. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    Seven is five, Rushour 2 is four. The awsom Fast and the Furious R1 is 6.
  11. boogie man
    boogie man
    Dec 4, 2001
    233
    19
    Sunny Berkshire !!
    pearl harbour region 1 thats 7
  12. mjn
    mjn
    May 24, 2001
    23,499
    Herts, England
    +11,906
    Thrill Seekers
    Predator
    Die Hard Trilogy
    The Mummy
    The Mummy returns
    Terminator 2
    Any Superbit title
    shall we keep listing the titles........??
  13. PaulW
    PaulW
    I stand erected! (although I did specify decent films so jingoistic Pearl Harbour and irritating Mummy returns don't count...)
    PS: mjn - you were right - just needed to select DTS from the audio set-up options. Thanks a lot.
  14. mjn
    mjn
    May 24, 2001
    23,499
    Herts, England
    +11,906
    no problem!
  15. Neon
    Neon
    Jan 8, 2002
    3
    Nottingham area
    Just for fun (!) I went onto play's R2 homepage and entered DTS in the search box ... 78 titles.
  16. mjn
    mjn
    May 24, 2001
    23,499
    Herts, England
    +11,906
    on play, just goto genre, and you can select DTS titles.......you don't even have to search!
  17. Kevo
    Kevo
    Aug 23, 2001
    5,448
    Manchester
    +166
    Dances With Wolves (R2)
    I always go into the Audio set up whenever playing a DVD. I've known some to default to Dolby Pro-Logic.
    Nowadays they usually default to DD5.1.
    A friend of mine watched Predator (R1) in DPL without realising you had to manually change it to DD5.1 in the Audio set up.
    He then watched it again straight after on the correct setting!
  18. BadAss
    BadAss
    Feb 2, 2001
    2,967
    England
    +182
    But which is the daddy of them all?
  19. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    For me, the R1 DTS version of 'Saving Private Ryan', now very closely followed by 'The Fast & The Furious'.
  20. mjn
    mjn
    May 24, 2001
    23,499
    Herts, England
    +11,906
    Gladiator R1, in DTS sounds awesome..esp. in the opening battle scenes
  21. Jase
    Jase
    Mar 16, 2001
    10,809
    United Kingdom
    +2,693
    The Haunting R1 DTS!! Awesome sound!
  22. pointon
    pointon
    Oct 21, 2001
    1,381
    38
    Right behind you!!!
    +3
    Also the original 'The Crow' movie, and the third 'The Crow: Salvation'. Very musical. And of course T2:UE.
