cant get constant picture from nlt box thru a 15mhdmi into hd fury2 to my monitor??
lawtoo
i have a panasonic th-42pwd6 and a hd fury2, with 15m hdmi cable. The problem im having is trying to get my ntl signal thru my 15m hdmi cable then thru my hd fury2 to b a constant stream, it keeps flickering on and off, i just cant seem figure out whats going wrong. plz help, cause i want it outside for england match tommorro:lease:
mambo1888
Hi bud, are you running 1080p? If you are are try it on 720p or 1080i and if it stays on then it means your hdmi cable is losing the signal as it is a long run, you will need either a better hdmi cable or a booster at the panasonic end which is probally a cheaper option. You can get boosters for under a tenner some come with a 5v adapter which i found to make a big difference when watching blu rays on my projector. Before i added the booster i would loose the picture from time to time when watching anything 1080p. I now have a 10m hdmi cable from my amp to a loops booster then a 1m hdmi cable to the pj and no loss of picture anymore:thumbsup:
Amazon Fire TV Cube Gen 3 Review: Coming Soon
