can't get anything to play
Discussion in 'General TV Discussions Forum' started by jonallwright, Sep 7, 2005.
  1. jonallwright
    jonallwright
    I've got a toshiba 32wl56 and SD-350E player.
    I've downloaded a few clips from M$ and burned them to a dvd and they won't play - they were asf format
    so i re-jugged using divx converter and ended up with v small files but lost their resolution - down yto 7xx X 4xx and they were not v good.
    so i downloaded the 3 sample files from divx.com and they won't play either.
    what am i doing wrong?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Well I would say your DVD player (like many) won't play .asf files nor does it play all the flavours of divx especially when their resolutions may play a part.
    The only practical way to get HD into a display is via a HTPC (in one form or another) or a standalone unit which is networked to a PC.
    The PC being capable of playing a multitude of file formats and resolutions unlike a DVD player which is severly limited.
