markie76
My mum in London has an Echostar DSB-890 with monoblock LNB on 80cm dish which she uses to watch FTA Polish channels on Astra (19.2) and Hotbird 13B\C\E (13).
The channel 'TVP Polonia' has moved from Hotbird 13C 11179H transponder 133 to Hotbird 13B 11075V transponder 128.
She has asked me to re-tune her receiver which should be a simple job of entering the new frequency setup or doing a transponder scan then channel search. Same as previous channel moves.
However, this doesn't seem to be the case as having entered the new channel settings the receiver is displaying a signal strength of 75% but 00% quality (signal-to-noise ratio) and not detecting\displaying any network name.
When I look up other channels and the old TVP Polonia channel in the same setup screens the signal strength is 75% with quality hovering around 70% and a network name displayed.
I have used the details from Lyngsat and set the following parameters to auto;
VIDEO PID: Auto
AUDIO PID: Auto
PCR PID: Auto
A scan\search on 11075V finds nothing and a full satellite scan of Hotbird 13B finds 100's of channels except the new TVP Polonia channel.
What am I doing wrong?
The old TVP Polonia channel is displaying 'new broadcast' settings to use - but it mentions settings called ONID \ TSID \ SID - how do these map into an Echostar configuration?
With the video\audio & pcr set to 'auto' it should automatically detect them?
EDIT: If anyone reading this watches Hotbird 13B could you see if you receive anything on transponder 128 11075V
Any help much appreciated.
Thanks,
Mark
VIDEO PID: Auto
AUDIO PID: Auto
PCR PID: Auto
Thanks,
Mark
