cant get a signal on pdp504 from htpc via dvi
Discussion in 'Plasma TVs' started by davidfischer, Apr 24, 2005.
  1. davidfischer
    davidfischer
    im trying to connect my pioneer pdp504hde to my htpc via an dvi-hdmi cable but i cant seem to get any signal. when connected via vga it works fine. any ideas/?
  2. ukdan
    ukdan
    Feb 16, 2005
    1,124
    swindon
    +84
    what spec is your htpc? i.e graphics card make/model, driver version etc.
  3. Dutch
    Dutch
    Dec 5, 2002
    2,590
    3
    North Yorkshire
    +278
    David,
    The media box will not accept native rate via the HDMI, only by the VGA input. You could try 1280x720 @60Hz which is an HD video resolution rather than a 1280x768 computer resolution. Hope this helps.
    Steve
  4. Dog with 3 legs
    Dog with 3 legs
    I'm not sure if it will take 1280x720 @ 60hz. I'm pretty sure I had to set mine at 1280x720@ 50hz before I got a picture. Then it was very impressive.
  5. davidfischer
    davidfischer
    how do i set the display properties to 1280*720 ? i can only see 1280*768 as an option...even in powerstrip.
  6. Dog with 3 legs
    Dog with 3 legs
    In Powerstrip set it using "custom".
