Can't get 20mbps with current router
Discussion in 'Networking & NAS' started by carol_s, Sep 20, 2007.
  1. carol_s
    carol_s
    Aug 26, 2007
    393
    28
    Torquay, South Devon
    +31
    I have cable broadband (Virgin) and I have just updated to their 20mb/s service. Unfortunately I can only get around 7 to 8mb/s when connected via my Netgear WGT624 router.
    If I connect directly to the computer I can get the full 20mb/s speed, so it is obviously my router which is not up to the job. Can anybody recommend a router (preferably wired+wireless) which is capable of doing the job.
    At the moment I am looking at either:-
    1. Belkin N1 Wireless Router (or do I need their Belkin N1 Wireless Modem Router)
    2. Linksys WRT150N 300Mbps Wireless Cable/DSL Router or
    3. Netgear WNR834B RangeMax Next Wireless Cable/DSL Router
    Thanks for any information/recommendations
  2. t72bogie
    t72bogie
    Jul 17, 2007
    3,102
    UK
    +532
    Id go the WNR834B myself
    but before that - have you tried upgrading the firmware on your router ?- that seems very slow - that router should do about 25-30Mbps WAN to LAN throughput ...most consumer routers were built to do that until 802.11n came along
  3. carol_s
    carol_s
    Aug 26, 2007
    393
    28
    +31
    Thanks, I've tried (via the router's html page) to upgrade the firmware, but it says there are none available :(
    Thanks for the response
  4. Jayceef1
    Jayceef1
    Dec 3, 2005
    Gravesend
    +11
  5. t72bogie
    t72bogie
    Jul 17, 2007
    3,102
    UK
    +532
    try checking it manually - look on the status page for the version, check version of the router on the bottom label
    then here for your version and latest firmware
    http://kbserver.netgear.com/products/WGT624.asp
    download the file, then upgrade manually in the router GUI - then do a factory reset afterwards
  6. t72bogie
    t72bogie
    Jul 17, 2007
    3,102
    UK
    +532
    ps - also check the MTU setting in the router (wan set-up page I think) is set to 1500...if its unusually small it will restrict throughput
    another thing - when you are connecting to the router is your LAN adapter connected at 100Mbps? (I just find it odd that the router is so slow - ive installed a few of those in the past)
  7. carol_s
    carol_s
    Aug 26, 2007
    393
    28
    +31
    Thanks for that info. I updated the firmware from 4.1.11 to 4.2.11 - but still no 20mb/s, resolutely stuck at around 7mb/s. Connect directly to the built in LAN port and immediately get the 20mb/s.
    The MTU Size (in bytes) is set to 1500.
    How do you do a 'factory reset' - couldn't find anything like that so I powered off and then back on again after about 10 seconds.
  8. carol_s
    carol_s
    Aug 26, 2007
    393
    28
    +31
    Ooops, forget the last sentence - found the factory reset button on the router - pressed that in to reset the router - still no joy.
    However this might now be because I am in the 'throttling' period where everybody would appear to have their speeds reduced to around half of what you have paid for. I'll retest tomorrow morning
  9. carol_s
    carol_s
    Aug 26, 2007
    393
    28
    +31
    Well I ordered a new router (D-Link DIR-655) after reading several reviews - and after setting it all up I am now getting close to the 20mbps (varies from around 17mbps to 19.7 mbps) although this drops to around 12mbps when connected wirelessly to my laptop. But I can live with that as I tend to use the main computer for internet access.
  10. t72bogie
    t72bogie
    Jul 17, 2007
    3,102
    UK
    +532
    thats not bad - thats currently the fastest consumer router on the market for WAN to LAN routed throughput so its go to be the Virgin service rather than the router causing any delays
