A family member is in hospital long term and since the TV in the room was an old Grundig tv without a remote. I decided to use hvis own tv, I'm not sure which modem it is. But its newer than 2019. The old Grundig had no problem findung the channels. But not so easy with with the samsung. Since it is a screw terminal on the coax terminal on the TV. I brought the coax cable from his own cable box. But in the hospital I'm not sure what system they use. It's anyway a cable outlet from the wall.
I tried a numerous search types on the TV, digital and analog. Broadcasting network, antenna and so on. Manual search is i possible since I don't know what settings to use. I have a suspicion the signals are digital since the old tv showed tv channel info, not tv guide but what channel it is on screen.
Hopeless, had to set the old tv back and went with unfinished business. With a cancer sick member that can not get out of bed on his own
So is there difference in types of coax, one with digital box and one with a outlet that reminds of the old cable outlets before the boxes came. In my head coax are coax.
Please help
Please help
