Can't find IP address
Discussion in 'PS Vita Forum' started by dave1de, Oct 19, 2005.
Tags:
  1. dave1de
    dave1de
    Nov 16, 2004
    2,168
    48
    +33
    Ok when I get this connected up to my wirless router, it finds the connection OK, but times out when connecting, it says ip address search timed out and if I enter it manually it also doesnt work
    Any ideas??
    Dave
  2. aligebes
    aligebes
    Jan 2, 2004
    233
    Edinburgh, Scotland
    +3
    Sounds like it's not getting an IP address from your router, please post:
    What firmware is on your PSP
    What version of router you have
    What firmware is on your router
    If you have a router that is B/G compatible, make sure it's not set to G only as the PSP is not yet G compatible.
    Not sure what else to suggest until you post a fuller description of your wireless setup, may be an idea if you also mention if you are on ADSL or cable.
    That way, people here may be able to assist you better
