If the remote is rev.8 then 0206 will work.
http://www.avforums.com/forums/showpost.php?p=3812591&postcount=2259
http://www.satcure.co.uk/accs/page3a.htm
Note: The LG codes that Sky have provided us to work with our newer television sets are; 0037, 0056, 0060, 0065, 0080, 0081, 0125, 0137, 0178, 0191, 0204, 0244, 0245, 0275, 0318, 0389, 0391, 0398, 0405, 0459, 0502, 0742, 1146, 1367. We also have some older codes; 206, 037, 060, 065, 080, 137, 191, 244, 245, 275, 318, 389, 391, 398, 405, 459, 502. The codes are stored in a database of the Sky remote. If the above codes don't work you may need to buy the latest Sky remote. Otherwise it is a matter of waiting for the new Sky remote which may have the updated codes. Best regards, LG Electronics.
http://www.satcure.co.uk/tech/digicode2.htm#contrib
Did you try 0065?
