Can't find a componant cable for my new projector anywhere???
Discussion in 'Projectors, Screens & Video Processors' started by iMan, Dec 4, 2003.
  1. iMan
    iMan
    Mar 30, 2003
    34
    Can anyone help, I recently got a Mitsibushi XD300U DLP projector that has an unusual componant input, it is a 15 pin D (VGA computer type) female input socket.
    I need a lead with a 15 pin D male VGA on one end and 3 RCA (phono) socets on the other (to come out of my componant DVD player outputs).
    Maplins don't do them and won't make one for me, they say something about progressive scan not been supported??
    Anyone know where I can buy one of these leads as Mitsibushi didn't give one away in the box with the projector.
  2. Bristol Pete
    Bristol Pete
    Oct 18, 2002
    5,577
    Bristol.
    +321
    www.intoav.com
    Telephone number is on the site. Have bought several leads from them all top notch, especially the evolution component.
    Cap:)
  3. Peter Baker
    Peter Baker
    Sep 6, 2003
    621
    28
    LONDON
    +37
    This sounds like the same socket that OPtoma use on the H56. They supply a converting box which gives standard component connections on the other side. If you speak to a dealer this probably has a part number and can be ordered separately.
    Good Luck
    Peter
