Can't download to Pronto from Pedit
Discussion in 'Home Cinema Control & Remote Controls' started by sarll, Feb 26, 2003.
  1. sarll
    sarll
    Mar 19, 2002
    1,392
    63
    +126
    When i modify a ccf (from remotecontrol.com) and select dowload to rc device i get the following error message:
    Error downloading configuration file into RC device
    I also get this message if i upload my working ccf from my rc.
    I have tried reseting the pronto and saving the files as different filenames.
    Any ideas??
  2. NicolasB
    NicolasB
    Oct 3, 2002
    6,367
    Emily's Shop
    +844
    Have you tried tapping the Pronto screen to make sure it's "awake" (i.e. screen switched on) at the point where the PC is trying to connect to it? This sometimes helps.
  3. sarll
    sarll
    Mar 19, 2002
    1,392
    63
    +126
    jesus..what an idiot! Thanks for that - tapping the screen makes it work. The smallest things can give you such a headache!
    One other question though - i've uploaded my config (default with 2 macros) and saved it. I then downloaded a ccf off the internet and then restored my original saved file. This worked except the 2 macros i made aren't there. Is this normal?? Do i have to recreate macros?
    thanks
  4. NicolasB
    NicolasB
    Oct 3, 2002
    6,367
    Emily's Shop
    +844
    It took me a long time to work out that you had to wake it up when downloading. It was particularly odd in my case because it would upload just fine without being prodded. I actually had to go and check out the forum at www.remotecentral.com before I worked that one out.
    Can't help you with your other problem, I'm afraid. :(
  5. mjn
    mjn
    May 24, 2001
    21,419
    Herts, England
    +8,973
    its strange that you have to "wake" your pronto up....i don't..
  6. Steve Bate
    Steve Bate
    Nov 10, 2002
    677
    Tarporley
    +11
    I think it's something to do with the firmware and the newer versions of PE, I can upload from Pronto fine with v4 but I cant download, I have to use v 1.4, I'll give the "waking up" idea a spin
    Steve
