JonnyConcrete
Established Member
I put my vodafone sim in my new Nokia 6220c that is on 3 to try and copy my contacts. After putting my 3 sim back I couldn't use my games or live messenger, when I try and open them it says:
Unable to open:
Certificate MIDP2 Authority6 - Operator Protection Domain not found. SIM changed or removed. You may want to uninstall application.
After uninstalling messenger it wouldn't let me reinstall it (cant remember what it said).
I tried changing a few settings on my phone which just made things worse and it struggled to even go online for a few days. The customer services sent me a message that let me save the connection settings and after a while seemed to work. My phone has been really fast connecting to the net today.
Now when I try to download Live messenger I get this error:
SDF-ERROR
Oops!
Sorry there is a slight technical glitch.
If you try again now, this service should work. In the unlikely case it doesn't, hit the triangle key to return to today on 3. Sorry for the inconvenience.
don't worry about the details below, this helps our engineers.
Reference ukl43i5MSN-128590
Error code:000
Dare/Time Mon Jan 19 18:56:35
The customer services are pretty useless, Ive rang 3 times and they just go through the same steps as when I rang about my phone not connecting. and just keep resetting factory default settings and sending me the settings through a text message.
Has anybody heard of this SDF-ERROR or know what I can do to rectify this?
CS did book my phone in for repair but I would like to try and sort it myself if possible.
I wish I didn't put my old sim in now, the phone was working perfectly before.
Unable to open:
SDF-ERROR
Oops!
Error code:000
