Can't decide which DVD Recorder - Help!?!
Discussion in 'Blu-ray & DVD Players & Recorders' started by Starnzy, Jan 29, 2005.
  1. Starnzy
    Starnzy
    I am looking to buy my first DVD recorder and have seen a couple that I like, but not really knowing that much about them; which ones are good and which ones to avoid, I thought I'd post here and hopefully you guys can help?
    I am thinking of spending in the region of £300 to £400, although I could go slightly more if it was absolutely worth it.
    I will be using it mostly for playing DVD's but will do the odd bit of recording too.
    It's essential that it has Component Video output and 2 scarts. A digital input for my Mini DV camcorder would be useful too!
    It would be great if it could support both DVD + and -.
    So, I've seen 3 Sony's that I like the look and sound of - Perhaps you can give me some feedback on each of the models and what their Pros and Cons are?
    Firstly I see the Sony RDR-GX7 in my local Sony Shop reduced to £379 from £500. Nice brushed aluminium front and the guy said it 'was' the top of the range model before the HD versions came out, hence they are selling off the last ones. I think I read something about the GX7 not outputting progressive or something (whatever that means) which is not ideal?
    Then the main one I have been looking at is the RDR-GX700 which is also in the Sony shop for £379 instead of £400. This also 'looks' really nice but how does it perform?
    Finally, I see the Sony Hard-Disk models which is likely to be a bit out of my price range but I wanted to find out a bit more about them first before I wrote the HD models off. What are the main advantages of having an HD in the DVD Recorder? How does the HD model perform in comparison to the other 2 mentioned above?
    Any feedback on these queries would be much appreciated - Am I looking at some decent units here or are there others that are better that meet my requirements?
    Thanks in advance! :)
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Have a look at the 'Which DVD Recorder?' link in my signature - it answers the basic FAQs and discusses the 'benefit' of multi-format recording support (virtually all machines will playback + and - discs burnt on other machines).
    The Sony GX7 is a good DVD recorder - and effectively has the same encoder as the new models - although there are better machines out there. Note that the GX7 output is not progressive (if that matters to you).
  3. Starnzy
    Starnzy
    Thanks for your quick reply.
    So if you could get a GX7 OR a GX700 for the same price, which would you go for out of the 2?
    I will check that link out now, thanks again.
  4. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Probably the GX700 - mainly because of the timeslip ability and progressive scan- but there really isn't much in it. It also has DVD+R support which the GX7 doesn't.
    In it's day the GX7 was vastly over-priced without any good reason (i.e. better performance). Obviously with the new models out they are now reduced - if you can pick one up you ARE getting a very good DVD recorder and won't be disappointed.
    Have you ruled out the HDD option BTW? The quickest test to see whether you want a HDD/DVDR combi is to ask yourself: do I want to make editted recordings that play on other DVD players?. If the answer is yes buy a HDD/DVDR combi, if no then a standalone will be fine!
  5. SDHoward
    SDHoward
    Nov 1, 2004
    250
    Also are you likely to want to record more than 2 of hours of good quality tv while you're out (asuming you don't have sky + etc). If you're away for a couple of weeks then a HDD is an invaluable way to record all the episode of your favourite soap, or reality show or whatever. A DVD only gives you about 2 hours of good quality recording.
    It is possible to get HDD/DVDR combi from £350 (the now, much debated toshiba sx32 as an example, of which I am a happy owner)
  6. Starnzy
    Starnzy
    Thanks again for the replies - OK so now it looks like I am down to the GX700 or the HX900. Looking at the questions you have posed as to whether I need an HD unit, I probably would want to do some of that stuff at some point.
    1 - So, presumably the HX900 is just as good quality on both playback and recording as the GX700, has progressive output etc, but just has the added benefit of the HD (and a brushed aluminium front panel)?
    2 - Where do you guys generally buy your units from? Online or high street shop? Just wondering where you stand as far as returns go (in case anything happens to it 6 months down the line)? Obviously I dont want to get ripped off by shopping at the wrong place so any pointers would be much appreciated.
  7. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Effectively yes.
    Online! Much cheaper. I normally use www.rgbdirect.co.uk - who generally provide a fast, hastle free service but somepeople have reported problems with them.
  8. Starnzy
    Starnzy
    Ah yes I've heard about RGB. A colleague at work bought a Toshiba DVD player from them and when it went wrong he had weeks worth of problems apparently trying to get a replacement sorted. May have just been unlucky I guess. Certainly look like good prices on there. Do they Multi-Region all their units?
    Im not fussed if its fixed Region 2 or if its Multi-Region. Im always a bit worried how the warranty stands up if it has been modified by the retailer?
    Any other sites that you can recommend?
    Looks like I need to decide between £312 or £484 as far as RGB is concerned! Hmmm...
    Thanks for all your help so far!
  9. Rasczak
    Rasczak
    Apr 3, 2002
    21,702
    Warwick
    +2,578
    Not really - may I suggest you post a new topic - e.g. 'Best Online Retailers'. I don't want to recommend someone I haven't had sufficient experience with! If you do a www.pricerunner.co.uk search there are several other retailers selling it at a similar price - but I don't know how they rate.
