Can't connect to xbox live anymore!
everclear
Hi,i just swapped my netgear for the thomson 780wl router supplied for o2 broadband,i have the 360 plugged into it by an ethernet cable and it can't obtain an ip from the router? It was fine with the netgear,i can't work out the problem! Any ideas would be greatly appreciated.
CDR
in the xbox dashboard you didn't have it set up for a manual IP configuration did you?
Maybe you specified it to use a specific LAN ip in your old router which is incompatable with your new one?
Moogle
Have you tested the network connection on the 360 to determine where the issue lies ?
Moogle
Have you tried rebooting your router ?
Moogle
Does everything else connected to the router work OK ?
everclear
Yes,i've managed to get a ps3 working wirelessly with it so i can't understand the problem with the wired xbox connection
Guns_LotsOfGuns
Moderator/Games Reviewer
Moved to Live section.
