Can't connect to Shopping Channel
Discussion in 'Nintendo Wii-U & 3DS' started by Steve in sussex, Jan 5, 2007.
  1. Steve in sussex
    Steve in sussex
    But I can connect to the Net and all other channels ok... any ideas????
    :lease:
  2. oasismark
    oasismark
    Jun 1, 2006
    13,655
    Sheffield
    +3,710
    If everything else works fine, then it's just that the channel is down or busy.
    Happened to me, just try again later or tomorrow.
  3. Steve in sussex
    Steve in sussex
    Was like this the other night, so thought id try again in a couple of days, its still like it and wont connect at all...
  4. koolmacher
    koolmacher
    May 24, 2005
    50
    +3
    Im in the same boat bean unable to connect since xmas day keep getting error code 205927 please try again later. The forcast channel works as does the updater and the mail, Tried to contact nintendo by phone, constantly engaged, by email 3 times no reply, hmv has no idea when they will be getting any replacements.
    Not very happy with Nintendo at the minute!
  5. saleshark
    saleshark
    Oct 25, 2006
    97
    Shopping channel worked fine on mine last night, weather channel wasn't working just thinks sometimes they are down.
  6. pooley91
    pooley91
    Nov 9, 2006
    37
    If your Wii is geting it's IP address automatically using DHCP, then try changing it to a static address (including manually entering the DNS addresses) - this is the only way I could get it to work.
  7. pigdog237
    pigdog237
    Mar 31, 2006
    285
    Bristol
    +12
    I had the same problem - searched Google and found a suggestion on a Wii fanboy's blog/website. I'm pretty sure he suggested changing the "channel" of your wireless router from 6 (? Which I think is the usual default for most routers) to 11 (?). You need to connect to your router's settings using a web browser.
    I may have got the details a bit garbled due to my dodgy memory, so check what I've said! But it definitely worked for me...
    Search the forum for previous posts about this, I had more concrete, accurate information in a previous thread!
  8. pigdog237
    pigdog237
    Mar 31, 2006
    285
    Bristol
    +12
