cant connect netgear DG834GT to psp
Discussion in 'Playstation Forums' started by hertderg, Sep 3, 2005.
  1. hertderg
    hertderg
    Sep 25, 2004
    I'm stuck - Trying to connect my psp to the net via my netgear router and it won't work - it finds the SSID no problem, WLAN settings are none,addy setting set up via easy setting but i get a wireless connection error 80410D07 when trying to connect.
    Can anyone guide me through this please.
    cheers
    HD
  2. calibos
    calibos
    Aug 4, 2000
    930
    Ireland
    +33
    Did you set the router to b only or b+g mode yet.
    If your router is set to G only it wont work as the PSP only supports the 802b wireless standard?
  3. jinky32
    jinky32
    Oct 17, 2004
    346
    +6
    yeah i have the gt and it works fine. make sure it's set to b & g setting and all should be good.
  4. hertderg
    hertderg
    Sep 25, 2004
    yeah router is set to b&G, also tried b only but still no luck.
    can someone post their setting or guide me through it please
  5. hertderg
    hertderg
    Sep 25, 2004
    sorted at last
  6. zoidy
    zoidy
    Mar 18, 2005
    693
    Surrey
    +53
    Hi Hertderg,
    would be interesting (for others in the same boat) to know how you sorted your problem out. Were you using WEP encryption? I tried all sorts of things to try and get the PSP to connect to my Netgear router using WEP, but I think I just found out the problem why it wasn't connecting.
    It seems that the PSP does not support 128 bit WEP encryption. Anyhow, I updated to v2.0 and am now using WPA instead and that works like a charm, better security too.
    Cheers,
    Pete.
  7. atariboy
    atariboy
    Mar 31, 2005
    259
    Swindon
    +6
    I am having the same problem. I have no web encryption whatsoever but still cant get a connection
  8. hertderg
    hertderg
    Sep 25, 2004
