Can't change the time on my 506XDE!
Norbert666
Putting all the clocks back yesterday, I found I could not change the time on my Pioneer 506XDE.
I read the manual which says you change it under: Home Menu -> Options -> Analogue Settings
But my Analogue settings are greyed out.
My TV signal comes from my cable box; I don't use the onboard Freeview stuff, not do I have the tV tuned into any chanels, if that makes a difference.
Can anyone help? :lease:
James
ikon66
James
think you've answered your own question
6022tivo
I have the freeview setup, but never switched to it yesterday, but the time updated at about 2PM.
Apparently the BBC did not change the teletext, PDC Freeview time until about 1pm on Sunday(I think). So it may take time to update. I am assuming it gets the time from the DTV, but it may also get it from the text from the STB you use?
Is it ok now?
Norbert666
Is it ok now?
What? So the time is linked to Freeview? Can I not just set it manually as I did when I first set it up?
hughesy
sorry, don't mean to hijac the thread, but just want to ask a quick off the topic Q?
Do all pioneer plasma's come with a seperate tuner box?
S
sonofon
James
Shut down on the reciver, then it will promt you the next time you turn on the tv:-(
Had the same problem:-(
