Can't adjust volume with Sky remote on new TV
Discussion in 'Sky Digital TV Forum' started by ims3ola, Jul 10, 2005.
  1. ims3ola
    ims3ola
    Jun 21, 2005
    265
    Hi guys, i've just picked up a panny 32PD50 tv and i cant adjust the volume with the sky remote - i have to use the tv remote. All other buttons work on the sky remote except the volume one. It worked fine on my sony tv before?
    Any ideas?
  2. JayCee
    JayCee
    Jan 20, 2004
    20,055
    Lanarkshire
    +1,912
    You have to input a code for your TV make.....in your case Panasonic.
    If you go into the "Interactive" menu, then Sky cust services there is a page which gives all the codes for the different TV manufacturers, it's just a case of trying all the codes for your particular model until you get one to work.
  3. ims3ola
    ims3ola
    Jun 21, 2005
    265
    Thanks JC, all working now. :thumbsup:
