Canopus ADVC-100
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by dpnpg, Nov 6, 2003.
  1. dpnpg
    dpnpg
    Hi.
    I'm a newbie here.
    just wanted 2 ask if any1 knows a good place 2 buy the Canopus ADVC-100, saw it reviewed and priced @ £170 but can not find anywhere 2 buy it at that price,
    hope some1 can help,
    thx in advance!
  2. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    Never seen one priced at that
    Typically they are £229+ vat
    £199+vat at smart DV & Planet DV
  3. dpnpg
    dpnpg
    thx 4 that.
    I have a DVD writer,
    what else will I need to purchase to get this 2 work?
  4. vonhosen
    vonhosen
    Jan 6, 2003
    1,835
    41
    London
    +13
    The ADVC-100 will not come with any software. It doesn't need any Windows will just see it as DV Camera/VCR.
    You need a firewire card (Apparently it has some problem with some older cards with Texas Instrument chipsets) in your PC & the ADVC-100 will act as a converting bridge between your analogue source & your firewire into the PC. (It can also go in reverse converting your digital on the PC to analog out)
    I just use my authoring software (Vegas) to capture (manually as it doesn't have device control like with a DV camera). Edit the captured files , encode to MPEG (with Canopus Procoder) & then author to DVD files (with ReelDVD or Pinnacle Impression Pro) then burn to DVD (with RecordNow Max)
  5. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    A cheaper option would be to install a USB2.0 PCI card (if PC does not already have USB2.0) for around £15 and then get a USB2.0 analogue capture device from companies such as Dazzle, Pinnacle, Belkin etc for around £50.
    I found these for somebody else on www.ebuyer.co.uk
    Mark.
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Haven't got a clue how to link to another post, so here are the details from the post:
    www.ebuyer.co.uk
    Belkin Hi-speed USB2 DVD Creator £47.75 inc VAT
    QuickFind code: 46431
    Mark.
