Canon XM1
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by russ hirst, Sep 24, 2005.
  1. russ hirst
    russ hirst
    Jun 18, 2005
    30
    11
    Harrogate, N Yorkshire
    I read great things about the new XM2 version but does that mean the XM1 is now outdated or just available a little cheaper?!
    Any views on the XM1? I note is does not have Audio in, though it does have scope for an external mic to be used via a 3.5mm plug so all is not necessarily lost. Can't see if it has preset WB settings.
    It would be used mainly for wedding type work I have an eye on one that looks to be around £4/500.
    Any views please?
    Thanks chaps!
    Russ
  2. Roy Mallard
    Roy Mallard
    another good cam, only real failings are the lack of audio level control, the smallish 1/4.5ccds but it has got a cracking wee lens on it, and yes, manual, auto and preset whitebalance
