Canon s50 flashcard, which one?
runningback
Hi all,
I've bought a Canon Powershot S50 a couple months ago
and it came with a 128mb Impact flash memory card which worked for one day and then never again.
I'm using the original Canon 32mb now which works fine
but just too small.
Does anybody have the same camera or a similar one and can
recommend a flash memory card with a decent size (128mb or
256mb) that works well with Canon Cameras.
thx in advance,
Bernd
shoehorn
I've got the S45 and use Lexar - had no problems at all.
I'm surprised that the one that was supplied to you failed - have you informed the place you bought it from - there must be a fault with it.
runningback
thx for your recommendation, they're not too expensive either seems to be good.
The one i had was included by the guy who sold me the camera on e-bay and was included in the price for free so i think i won't bother....
Bernd
🎬 The Top 20 Most Anticipated Movies of 2024
Back
