Canon powershot A80 & A85 difference?
Discussion in 'Photography Forums' started by Fangorn, Sep 10, 2004.
  1. Fangorn
    Fangorn
    Nov 9, 2003
    555
    28
    UK
    +26
    Which is the best to go for?
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Despite the numbering the A80 is generally conceived to be the better camera.
  3. matiano
    matiano
    The only real difference is that the A80 has a smaller screen than the 85 but the screen does swivel on the 80 which can be handy. The only other major difference is how tricky it is to get hold of an A80 now :)
  4. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    Actually the A85 has a much smaller sensor which generates more noise in higher ISO pictures.
    It also lacks the flip LCD which is more helpful than you would imagine.
    The natural upgrade for the A80 is the new A95
  5. mandlebrot
    mandlebrot
    Aug 21, 2001
    426
    16
    Manchester, UK
    The A85 is not the upgrade for the A80 so please don't be misled, its actually the upgrade from the A75 and lacks not only some of the features like custom modes but also has already stated generates more noise in the higher ISO speed pictures.
    So in MO I'd go for the A80 if you can find one (some good deals can be had at the mo) or the A95 if you don't mind spending the extra.
