Canon MV750i To PC
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by gamala, Oct 3, 2004.
  1. gamala
    gamala
    Just purchased a Canon MV750i, can anybody let me know if it is possible to copy the Mini Dv Tapes to your pc and then to CD rom, if so what's the easiest way? I'm running XP (SP1) but the PC doesn't seem to recognise that I have the Canon attached.
    Many thanks
    Gary
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,484
    Rainham Essex
    +2,487
    The only way to connect a camcorder to a PC to download the video at full quality is via firewire.
    If your PC does not have a firewire port it can be added very easily on a PCI card that will slot onto the motherboard and should cost about £10 including the cable to connect between the cam and card.
    For help in getting the video onto CD have a look at the tutorials Here but TBH at under £50 for a DVD burner you really should upgrade to DVD and do your master pieces justice as the results from a CD will be poor compared to what the camcorder can achieve.
    Mark.
    ps, firewire aka iLink, ieee1394, DV port amoungst others just to help to confuse us all.
