Canon mv750i -Banding on playback
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by BENSONDOG, Jun 18, 2005.
  1. BENSONDOG
    BENSONDOG
    I wonder if anyone can help with a query.
    Just returned from holiday and attempted to edit footage taken on Canon mv750i , however when I try to playback there is horizontal banding on the playback or just the blue default screen with the "2-spooler logo" . This is interspersed with a decent recording.
    I don`t know if it`s a tape issue or the player, a bit worried as the warranty runs out very soon.
    Any suggestions gratefully accepted !!!
  2. pzd
    pzd
    Mar 30, 2005
    38
    I had a 'banding' problem, intermittently, with my 730i model.
    I used a tape cleaner and have not had the problem since (my Camcorder is about 5 months old).
    Best of luck.
  3. BENSONDOG
    BENSONDOG
    HI PZD
    Thanks for the tip.I think you are right. I played/recorded another two tapes thru and this appears to have resolved the problem.
    I`m a bit suprised as I`ve not used it much. Also relieved as I was browsing some threads this morning. Didn`t realise that CANON got so much stick for their camcorders.
    Thanks again. :clap:
