Canon MV600i Not Charging
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Swindle, Jun 14, 2005.
  1. Swindle
    Swindle
    I Have a Canon MV600i Digital Camcorder which is just under 2 years old. It has just decided to not charge the battery. I have replaced the fuse in the charger, but that has not solved the problem. The red charge light that should come on to show it is charging does not light up. When I remove the battery, and try to use from the mains supply, the screen lights up for a few seconds, and then goes dark. Have never had a problem with it before, and like always, family holiday is just around the corner, so would like to get the problem solved ASAP. Just a thought, would replacing the small back up battery make a difference?
    I would be most grateful if someone could shed any light on this problem
  2. ad47uk
    ad47uk
    Apr 21, 2005
    749
    +6
    I am not sure, but it sounds as if the charger itself have gone belly up. If you can get hold of a multimeter, you can test the output and see if it is putting out what it should.
