CAnon MV550i I.Link problem
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by D.H., May 27, 2003.
  1. D.H.
    D.H.
    Hi all!
    I connected the MV550i to the I.Link on my VAIO PCG-F403 on Windows 98 SE, installed the Digital Video Editing Kit (Presto VideoWorks) but I can not get the video onto my pc. It seams the system doesnt recognice the camera.
    What could be wrong?
    Any help highly appreciated!
    Thanks in advance!
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,312
    Rainham Essex
    +2,425
    What error message(s) are you getting when the camera is connected?
    What error message(s) do you get from the software when trying to capture?
    Can you see the cam from System devices in Control Panel?
    Make sure that the cam is connected and switched on before you start the capture/editing software.
    Are you connecting the cam via a 6pin (at PC) to a 4pin (at cam) DV cable or a USb etc. cable? Only a DV cable will work. USB etc is only for stills.
    What is your inside leg measurement :D
    (No I don't really need that one! :rotfl: )
    Sorry about all the questions, but this just might let us narrow down where the problem lies.
    Mark.
  3. army
    army
    Apr 24, 2003
    33
    Yes make sure you are using ihe correct cable and then go and get a copy of windows xp
