Canon Legria/Vixia HF200 SDHC-card
Jan Fredrik
Hello
I know this is an old camera, but it is not bad. Audio in , headphone out and a lot of manual control.
The problem is it does not accept class 10 cards for HD recording, so you can`t record on HD settings. I know there is a firmware uppdate, but it is going to cost me more than the camera did. Canon site says you can record HD with class 4 and 6 cards. I have tried ScanDisc class 4, but it does not work. Have anyone succseeded with any SDHC card? Maybe class 6? (wich is difficult to find here in Norway).
Regards
Jan Fredrik
stearman65
Established Member
Depends what you are using the results for & what you are taking. If it's fast action stuff a higher class is best. For the cost of a small card it's worth a try.
Emerton
Established Member
The OP is correct. The HF200 firmware throws up an error message if the card is not Class 4 or 6, regardless of capacity, although mine has worked with Class 10, simply by ignoring the message (although I wouldn't recommend it). If a card is formatted ('initialized' in Canon speak) and the write protect switch is off (up), it must be down to a fault, either the card or cam.
🎬 The Creator & Reptile, Guardians 3, The Others & Cutthroat Island 4K & Best/Worst Renny Harlin
Back
