canon ixus II firmware update for sd card compatability
Discussion in 'Photography Forums' started by jonnyv, Jan 10, 2004.
  1. jonnyv
    jonnyv
    Mar 31, 2002
    2,145
    48
    +41
    theres a firmware update for canon ixus II,
    'The SD card compatibility problem
    A compatibility problem has been found between DIGITAL IXUS II/PowerShot SD100 DIGITAL ELPH cameras and some SD card from other manufacturers. We apologize for any inconvenience you may have already experience because of this problem.
    [Problem Description]
    The [Memory card error!] message appears on the LCD monitor when the camera is powered on in Shooting mode.
    Image replay is impossible. The [No image], [Corrupted Data], [Memory card error!] or [E51] message appears on the LCD monitor when you try to view images recorded on the SD card in the camera's Replay mode.
    The [E50] message appears on the LCD monitor when you try to format the SD card in the camera and formatting fails. '
    Go Here
