mark.carline
Established Member
Has anyone here used or know about Tamron lenses with a Canon EOS 450d ?
I havent purchased the 450d yet and i am tempted to get a body only and go for a similar lens from the Tamron range as they seem to be alot cheaper.
Any thoughts ??
EDIT:
I have done a quick bit of research and (I think!) the Canon EOS 450d uses a "Canon EF lens mount, Canon EF-S lens mount" as it mentions here:
http://en.wikipedia.org/wiki/Canon_EOS_450D
So in theory all I need is the following adapter:
Tamron adaptall-2 Lens to Canon EF EOS Mount Adaptor
http://cgi.ebay.co.uk/Tamron-adaptall-2-Lens-to-Canon-EF-EOS-Mount-Adaptor_W0QQitemZ370147675659QQcmdZViewItemQQptZUK_Photography_CameraLenses_Lens_caps_hoods_adaptors_ET?hash=item370147675659&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A10%7C39%3A1%7C240%3A1318
and then I think I can use any of the tamron "adaptall-2" lenses like the following:
TAMRON 35 - 135MM F3.5 - 4.2 MACRO WIDE ANGLE ZOOM
http://cgi.ebay.co.uk/TAMRON-35-135MM-F3-5-4-2-MACRO-WIDE-ANGLE-ZOOM_W0QQitemZ400025992704QQcmdZViewItemQQptZUK_CamerasPhoto_CameraAccessories_CameraLensesFilters_JN?hash=item400025992704&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A10%7C39%3A1%7C240%3A1318
Tamron Adaptall-2 80-210mm F/3.8-4
http://cgi.ebay.co.uk/Tamron-Adaptall-2-80-210mm-F-3-8-4_W0QQitemZ190281455941QQcmdZViewItemQQptZUK_CamerasPhoto_CameraAccessories_CameraLensesFilters_JN?hash=item190281455941&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A10%7C39%3A1%7C240%3A1318
I know the quality might be be great (and maybe not for a primary lens) but for around 30 quid (if it works) it might be worth a shot (excuse the pun!) for a 2nd lens.
Any thoughts ??
EDIT:
