Canon EF 28-105 lens
Discussion in 'Photography Forums' started by dood, Feb 4, 2005.
  1. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I have the 300D with kit lens (18-55 EFS).
    I am considering getting the 28-105 for the obvious benefits of a larger focal range and it's slightly faster than the 18-55.
    Except for these advantages, is the quality of the 28-105 better (optically)?
  2. steeve
    steeve
    Dec 15, 2003
    20
    if its a Canon lens its going to be OK, the worst lens seems to be the cheapo 18 to 55 standard kit offering. Like the 28 to 200 lens....
  3. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
  4. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    What about the EF 28 - 90 USM?
    This is a cheap lens in terms of price. But is it better optically than the 18 - 55 EFS? I've noticed that the latest lenses (including the EFS 18 - 55) are micromotor and not micro USM. What does this mean?
    My main objective is to get better image quality without having to pay OTT, whilst also getting a slightly better focal range. If the changes are not going be significant I'll drop the idea and plan to get something like a 28 - 135 IS USM at a later stage.
  5. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I would suggest you buy a lens for EXACTLY what you want to use it for if you get what I mean??
    Any 'zoom' lens is a comprimise over 'Primes' which will give the best quality by far, but to fill your bag with Canon Primes to cover 10mm to 800mm would cost a small fortune.
    My main subject is Aircraft, so I need big mm's. If I had the money...
    Canon EF 200mm f/1.8L USM
    Canon EF 300mm f/2.8L IS USM
    Canon EF 400mm f/2.8L II USM
    Canon EF 14mm f/2.8L USM for ground shots
    Had to settle for the 100-400mm L zoom..
    Don't knock the kit lens....it ain't too shabby for the cost.
    A 50mm f1.8 should be on your list....near L quality for around £80.
    All the shots here (apart from the 1962 and 1980's ones)............
    http://www.airliners.net/search/pho...rnet.com&sort_order=views&distinct_entry=true
    were taken with the cheap 18-55, 50mm or 75-300 Canon glass....not yet used my 100-400 in anger at an airshow...roll on spring.
    Go to a shop, strap on a L lens and shoot off a few frames to take home and compare with 'normal' glass.....
  6. tomson
    tomson
    Jul 19, 2000
    1,959
    Berk'amsted
    +186
    I'm guessing L series lenses are out of his price range.
    The 28-90 isn't a great lens to be honest - used one a while back on a photography course and wasn't too impressed with it's results. Cheap but not particularly cheerful. It won't add a great deal to your range either, so you might yearn for something longer very quickly (depends on your usage of course)
    The 28-135 IS is much better - has a much more useful range, the 135mm end gives a good reach on a dSLR, and the IS helps in low light/shakey hands conditions etc. Its pretty sharp too -if you avoid using it wide open. Johndm's suggestion of the 50.1.8 is spot on too - a great little lens (apart from it's build).
  7. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    I've taken a few shots with both the 18-55 and 28-90 at 18, 28, 55 and 90 mm at various apertures.
    Will give my comments after assessing the shots.
  8. dood
    dood
    Aug 4, 2000
    947
    28
    Hobart
    +38
    After reading so much about how lousy the cheap kit lens is, I was convinced that the cheap 28-90 (4-5.6) would at least be better.
    Was I wrong! The kit lens (EFS 18-55) is streets ahead. Especially at wide open apertures where the 28-90 was fuzzy and showed obvious CA at the edges.
    I tried really hard to get equivalent images and the only time the two lenses were comparable was in good light, at F10 with the 18-55 at ISO 400 and the 28-90 at ISO 100!
    Needless to say I sent the 28-90 back! I will certainly consider the 50mm 1.8 and possibly the 28 - 135 IS USM.
  9. HotblackDesiato
    HotblackDesiato
    Dec 4, 2002
    1,170
    63
    USA
    +226
    My personal favourite around that range is the 24-85.
  10. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    Yep..the cheapy EFS 18-55 ain't too shabby eh?
    You can't get 18mm anywhere as cheap as the EFS (actually 28mm-88mm on the 300D because of the crop factor of 1.6x), and as long as you keep it stopped down to around f/8 results will be pretty good. Open her up though, and things get a bit rough.. :eek:
  11. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
