Canon DC230 Camcorder Recording Problem
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by cool4cats, Jan 6, 2012.
  1. cool4cats
    cool4cats
    Nov 26, 2010
    11
    Please can someone help me?
    I have a Canon DC230 camcorder and have only used it a few times since new.
    It's been working fine up until a few days ago, now when I record a video and play it back I can hear very loudly the sound of the mini disc rotating ... it sounds like crickets in the background and is really annoying!
    I don't understand why this has suddenly started to happen, I've never had a problem with it before ... all my recordings have been perfect without any sound of the disc being recorded on the sound track.
    I would greatly appreciate it if someone could tell me what the reason for this is.
    I have used a DVD lens cleaner disc and it's not made any difference.
    TIA
    Gill
  2. chrishull3
    chrishull3
    Aug 3, 2006
    3,999
    103
    Yeovil
    +279
  3. cool4cats
    cool4cats
    Nov 26, 2010
    11
    Thanks for your reply.
    The discs I'm using are the same discs I've used before and they worked fine then. I've also tried a different brand of disc and have the same problem.
    I may have to send it to a repair centre as you suggested, it depends on the cost of course.
  4. 12harry
    12harry
    Oct 10, 2010
    4,716
    103
    London
    +383
    Way off ideas=
    1) leave it running until the battery is exhausted, maybe it needs to free-up the bearing.
    2) charge the battery fully(or new one) and try again, it may be lack of power is affecting things.
    3) leave it to record a radio/TV and then check "noise" - it may be in the past you had a stronger audio, so it wasn't as obvious.
    4) put some silicon sealant on the drive shaft - that might silence it - next you have to work-out a permanent "fix"
    As so often the case, it's not "what you do" - rather it's "how" . . . . . Good Luck.
  5. chrishull3
    chrishull3
    Aug 3, 2006
    3,999
    103
    Yeovil
    +279
    Oh so assuming you have given it a prolonged test in quiet surroundings where noise can heard easily you have to decide whether to try any minor repairs before a repair centre,dont risk doing more damage though.
