Canon 400D - Possible flash fault?
Discussion in 'Photography Forums' started by Gavin_Hall, May 2, 2007.
  1. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    876
    46
    Maidstone, Kent
    +179
    I have just taken delivery of a nice Canon 400D, together with a Sigma 17-70mm lens. I am still going though the manual getting to grips with all the different features.
    One thing which is concerning me is that I have noticed that when taking a picture that will require a flash, the flash fires off a stream of flashes the minute I half-depress the shutter release button to get focus lock! The stream of flashes isn't consistent, sometimes it is 6 to 8 flashes, sometimes only 1,it's like a strobing effect.
    Obviously, I expect the flash to fire, but not until I have fully pressed the shutter release, not before!? I have checked the red-eye setting and that is off.
    Am I missing something, is this a fault, I can't find any reference to this within the manual?
    Gavin
  2. horribleman
    horribleman
    Jan 28, 2005
    527
    28
    +47
  3. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    876
    46
    Maidstone, Kent
    +179
    That was my thought, but I've just this second read an article that confirms that as well, thanks! :)
    It really distracts the person being photographed !
  4. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Like all Canon DSLRs It does use its flash for AF assist :)() but it shouldn't need it if the focusing conditions are not "demanding"
    If it is a constant problem I would have it looked at. Try using manual focus and see if it happens ( shouldn't)
    Also it shouldn't happen in conditions where focusing should be easy.. unless it is the lens that is struggling
  5. RobDickinson
    RobDickinson
    Mar 8, 2001
    4,756
    Christchurch , New Zealand
    +748
    You should be able to switch of the AF assist on the flash btw, somewhere in the menu's.
  6. Coolhand
    Coolhand
    Jan 17, 2002
    61
    +8
    You can switch it off in the menu, it's one of the first things I did when I got the camera, cos all my early portraits were of people squinting.
  7. Gavin_Hall
    Gavin_Hall
    Apr 18, 2001
    876
    46
    Maidstone, Kent
    +179
    Thanks for that, I found the option deep in a customisation menu! Now time to play :)
