canon 350d flashgun?
Discussion in 'Photography Forums' started by mickey, Jun 11, 2005.
  1. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    hi guys. yet another question about my new camera, Are the older EZ series flashguns like the 540ez flashgun compatible withe the 350d and capable of high speed flash sync?, there seem to be plenty of them around used but I cant figure out if they are fully compatible or not, or do i have to get one of the newer EX series flashguns for full compatability. anyone with a 350d own an external flashun?, your experienced opinion would be welcome.cheers Mike
  2. kenlynch
    kenlynch
    Jun 7, 2005
    111
    Rochdale
    As far as I know the 540EZ will not work properly as the newer range of EOS don't support TTL metering (only E-TTL), you should be able to use it manually though.
  3. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    You need an ex mike, the EZ was not designed for eos digital cameras and why even if you could, (which you can't) would you want to miss out on E-TLL ll of the 580;)
    Jamie has one (mr jones). If you'd like more advice go here http://photography-on-the.net/forum/forumdisplay.php?f=35
    "All current Canon digital cameras with hotshoes - both the interchangeable-lens SLR cameras and the point and shoot digital cameras - support E-TTL (or both E-TTL and E-TTL II) and do not support either TTL or A-TTL. Even Canon digital cameras with internal popup flashes are E-TTL only. This means that only Canon EX flash units or third-party flash units with E-TTL support can be used with Canon’s current lineup of digital cameras. Older E and EZ flash units will not work correctly - no automatic through the lens metering is possible. You can get manual-capable EZ flash units like the 540EZ to fire in manual flash mode but this requires external flash metering."
  4. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
  5. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    thanks for the replies guys, think it will have to be a 420ex for now the 580ex is out of my range at the moment (or so wifey says) since i still have to buy a 28-135 is lens yet, just one more query does the 350d have flash exposure compensation?. cheers Mike
    P:S great link to that website Seany :smashin:
  6. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    Hi Mike, yes it does. Have a look at page 100 of your instruction manual.
    ASH1
  7. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    its a top bit of kit, if a bit pricey, but its worthwhile in the arsenal of gear to have. one day ill learn to use it to get some nuts effects etc
  8. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    gonna go for the 420 if i can get jessops to do a pricematch 2morrow for £142.00, less my £35 canon rebate makes £107.00 for a pretty good starter flash. cheers Mike
    P:S got the bge3 grip today and it makes the camera feel so much more comfortable even while using in normal mode horizontally
  9. seany
    seany
    May 1, 2003
    2,997
    61
    Manchester city
    Look foward to seeing some of your shots mick. Flash is a complex issue and one i'm looking foward to getting in to.
  10. p00hbear
    p00hbear
    Oct 31, 2002
    1,203
    +33
    mickey, where can you get the 420ex for £142 (I have canon vouchers too)?
  11. mr jones
    mr jones
    Oct 23, 2004
    1,041
    41
    (S)cumbria, UK
    +21
    when i bought my flash the 420 was about £240.
    my 580 cost £289 i think
  12. p00hbear
    p00hbear
    Oct 31, 2002
    1,203
    +33
    just to let peeps know I managed to price match a BG-E3 for £89.99 from £129.99 at Jessops by printing out from Fotosense - get yours now!
    PS - they wouldnt accept my NUS card - although it may be just dependent on branches and not available on price matching but was worth a try...
  13. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
  14. p00hbear
    p00hbear
    Oct 31, 2002
    1,203
    +33
    mickey, thanks for the info. I should have got it from HK when it was just under £85 - drat!
