cannot get text or interactive on sky-help
Discussion in 'Sky Digital TV Forum' started by Gadjet, Jun 13, 2002.
  1. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    When I press for text on all sky channels, making sure sky is pressed first then it says "for text access press tv first then press text on control". Also I cannot use interactive(especially when footbasll is on)
    Anything wrong with box or handset. Or is there a way of getting it working again with control numbers
    help much appreciated,
    Phill
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +975
    Has the red active dot vanished from the BBC footy and various SKY1 programs?
    If it has then a simple reboot should be all that's needed.
  3. Gadjet
    Gadjet
    Aug 14, 2001
    411
    Wrexham
    +7
    Thank you,
    You are right ethere is no red dot, sorry for being simple but does areboot meaning turning off at plug and restarting?
    phill
