Cannot Factory Reset Matsui M22LID618 TV
Discussion in 'LCD & LED LCD TVs Forum' started by Rex Alsatian, Aug 31, 2017.
  1. Rex Alsatian
    Rex Alsatian
    Aug 31, 2017
    2
    London
    I think I need to reset my Matsui M22LID618 TV as I seem to have upset the channel setup. I've tried the following resets without success. Failing this, I could manually reset but I need to know the individual settings for Programme/Band/Channel/Standard/Search, etc.
    Can anyone help please?
    Matsui Service Menu Instructions
    Matsui Service Menu Method 1
    1. With the TV in standby:
    2. Press and hold the {i} button on the remote while pressing the {POWER} button on the TV.
    3. The TV will turn on with the Service Menu displayed.
    4. Use the {UP}{DOWN} buttons to select menus/options.
    5. Use the {LEFT}{RIGHT} buttons to change settings.
    6. To exit, turn the power off.
    Matsui Service Menu Method 2
    1. Turn the TV off.
    2. Press and hold the {MENU} button on the TV while pressing the {POWER} button on the TV.
    3. Wait until the power light turns on then press the {POWER} button on the remote.
    4. The Service Menu will be displayed.
    5. Use the {P+} {P-} buttons to select options.
    6. Use the {VOL+} {VOL-} buttons to change settings.
    7. To exit, turn the power off.
    Matsui Service Menu Method 3
    1. Turn volume all the way down to '0'
    2. Then press and hold the {VOL -} button on the TV and the {9} button on the remote control for few seconds.
    3. The Service Menu will be displayed.
    4. Use the {CH+} {CH-} buttons to select items.
    5. Use the {VOL+} {VOL-} buttons to change values.
    6. To exit, press the {8} button.
  2. JayCee
    JayCee
    Jan 20, 2004
    23,885
    Lanarkshire
    +2,589
    Why are you faffing about in the service menu?
    That's a sure fire way of bricking your Tv especially if you don't know what you're doing and I get the impression you don't.
    What do you mean by "I seem to have upset the channel setup"
    What are the symptoms.
    Are you aware there was a change to the Freeview channel lineup recently?
    The settings you're asking about refer to the analogue tuning menu.
    We no longer have analogue broadcasts in the UK.
  3. Rex Alsatian
    Rex Alsatian
    Aug 31, 2017
    2
    London
    Hi JayCee
    I was being daft! I hadn't noticed that the TV came from the analogue-to-digital switchover period so it had a TV and a DTV button on the remote. I was pressing the TV button (and missing the fact there was a separate DTV button) which is why I was having problems!
    Easily sorted.
    Thanks again.
