Cannot change ID TAG for certain songs
Hi, I have been replacing my mp3 collection with FLAC files and as usual use a TagandRename to edit the tags. However some albums won't change and so far have just downloaded from a different source. But I want to be able to get to the root of the problem.
For example I have an album that have renamed the genre to 'Industrial Metal' in the TAG but on my Hiby R3 Pro player it shows up as 'Metal'. I tried a different tag editor yet it showed the genre that I had changed it to.
I tried to remove all tag information within TagAndRename and then re-enter but still does not work. I have had this problem in the past with my mp3s but never been able to solve it.
Any ideas of how to solve?
James
rpr
Or try Tag Scanner
I tried Mp3Tag again and changed to the directory to the album folder that would not change the tags. Within Mp3Tag it is showing the tags that I changed them to not the ones that are showing in my Hiby player.
I then clicked on each song and pressed the save button. But when I copied it back to the Micro SD Card and updated the Hiby database, it still shows the old tags.
One thing I have noticed though. Of the two albums that I had problems with both say FLAC (FLAC IDv2) so tried one of the albums that is ok and that just says FLAC. So I am wondering if its the fact they they are IDv2. Is this using Version 2 of the Tag? Im wondering if this is the problem?
I have not tried Tag Scanner yet but could give it ago.
pxr5
When using mp3tag, open the song/album and on the menu bar select 'view - extended tags'. You'll then see all the tags from the loaded song/album. I've found that certain programs will read these other tags when forming their database.
Jaded1
Thanks to the Bluesound Node I am now in the process of ripping 80,000 songs (not albums or CD's lol) to FLAC with EAC. Sometimes though the node fails to notice some artwork. Even if I replace it with MP3 tag.
Any ideas?
Any ideas?
I have noticed some of my albums fail to show the album art. I discovered that these where high Res and high file size. The solution was to download a smaller file. I found 1000 x 1000 and under seems to be Ok. But I try to find one around 500 x 500 and loads fine
