Can you view jpegs on DVD-R on HS2?
Discussion in 'Blu-ray & DVD Players & Recorders' started by Sheks, Aug 14, 2003.
  1. Sheks
    Sheks
    Jul 23, 2000
    523
    England, Surrey
    +24
    As the title really.
    Been considering this DVD recorder for some time (also considered the E60).
    I see the HS2 has a PMCIA slot, but could I burn jpeg pics onto a DVD-R on my pc and play them back on the HS2?
    Thanks in anticipation.
    Colin
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,238
    Warwick
    +2,281
    With the HS2 you can copy them to the HDD or to DVD-RAM (from which you can move them to your PC) but you cannot burn a DVD-R gallery.
    You can create a DVD-Video of images on your PC quite easily. Several applications let you do it or you download a freebe like Spruceup which would let you author something simple (you just add a 'menu' for each picture). These would then be playable in any DVD player (including the HS2).
  3. Sheks
    Sheks
    Jul 23, 2000
    523
    England, Surrey
    +24
