Can you use the Cursor keys on the Sky remote?
Discussion in 'Sky Digital TV Forum' started by Jon Weaver, Oct 12, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I need to be able to use the Cursor keys on the Sky remote when in TV mode, to use Teletext on my Sony TV.
    Its clear that they just don't work, as the LED on the remote doesn't even flash when you press them.
    I have always thought it impossible, but, I when you consider that some 'codes' on the remote, don't even let the 'fast text' buttons work.
    Is anyone able to use their cursor keys on ANY TV?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Nope, the cursor keys don't work on my TV either but fast text works ok.
    I don't quite understand why you need them for analogue teletext though.
    To use it I've found the fast text and channel +/- keys are all I need.
