Can you use SKY+ remote on Hitachi C42PD3000
Discussion in 'Plasma TVs Forum' started by midknight, Dec 19, 2003.
  1. midknight
    midknight
    Oct 8, 2000
    4,671
    Billingshurst, West Sussex
    +1,395
    Just got my Hitachi C42PD3000 and was wondering if the SKY+ remote can be used to control the panels volume etc. - as at the moment is is not working.
    Also is it normal for the media box to get pretty hot when switched on ?
    Cheers!
  2. deman77
    deman77
    Aug 20, 2003
    263
    16
    London
    Mine, controls panny D6 and an amp, but before I set it up to control the amp it used to control volume level on plasma.
    go to digital spy, they have a good thread for SKY remotes.
  3. JAMBO
    JAMBO
    When I got my Sky+ installed, the engineer told me that the remote would not control my plasma (Hitachi 42PD3000). Though Sky engineers have been known to be wrong....occasionally !!
  4. chrise
    chrise
    Dec 13, 2002
    556
    28
    Hampshire
    +46
    I have got most of the controls working on my 42PD3000(not teletext and the clour buttons I think) by using a code found on the list in the Sky part of the interactive service. There is a list for Hitachi which I tried in turn, one about two thirds of the way down worked -sorry I forget which.
    Best of luck
  5. Elvis
    Elvis
    My sky+ remote controls my hitachi 42pd3000. The codes for hitachi TVs are in the back of the Sky+ manual. Just follow the instructions and you'll get it to work. I haven't tried using all the functions but it will certainly do on/off, channel change and volume control/mute.
