Can you use a wheel on the bed?
Discussion in 'Playstation Forums' started by rupert-hd, Nov 29, 2010.
  1. rupert-hd
    rupert-hd
    May 14, 2007
    268
    +13
    Got my tv set up in my bedroom,not much space either side of bed to use a wheel,so just wondering is it possible to use a wheel while sitting on the bed?
    Obviously you wouldn't be able to use pedals,but do some of the wheels come with paddles?
    If it is possible to do can anyone recommend a wheel suitable to use on the bed and compatible with gt5 :smashin:
  2. wongataa
    wongataa
    Jan 11, 2009
    1,615
    113
    Birmingham
    +553
    Not really. You need to attach the wheel to something that won't move. It would be a bit pointless without the pedals as well.
  3. Rob_J
    Rob_J
    Aug 24, 2005
    1,001
    +87
    Im using mine on the bed a Logitech Driving force wireless, sits on your lap and has paddles for brake and accelerate.
  4. rupert-hd
    rupert-hd
    May 14, 2007
    268
    +13
    How do you find it? Is it quite easy to use and does it hold still or is it moving all over the place?
    I take it you prefer your setup to a controller then?
    Cheers :)
  5. Rob_J
    Rob_J
    Aug 24, 2005
    1,001
    +87
    Its fine, it works perfectly no movement. To be honest im not too fussed controller is as easy i find.
  6. Kelltic
    Kelltic
    Sep 7, 2006
    2,387
    116
    Belfast
    +1,019
    The Logitech Wireless will be perfect for you in this case, especially for the money :smashin:
