Can you use a PT600 tuner with Panny series 3?
Discussion in 'Plasma TVs Forum' started by pinnocchio, Jan 15, 2004.
  1. pinnocchio
    pinnocchio
    Can you use the PT600B tuner with a TH-50PHD30 Panny and if so which terminal board should you use?
    Thanks in advance.
    P
  2. pinnocchio
    pinnocchio
  3. franc
    franc
    Sep 12, 2002
    450
    Bucks
    +7
    Hi and welcome. As far as I can recall, the PT600B is only compatible with the series 5 and 6 panasonic plasmas. The older tuner box (PT300) should work on your series 3.
    hope this helps. If this is incorrect then maybe someone else can post to put things straight.
  4. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    franc is correct the 3 series uses the older tuner box which is unfortunate as its the size of a small house !! ;)
