Can you use a PSU outside of a computer?
Discussion in 'Computer Components' started by mikeaitch, Jan 9, 2008.
  1. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    This sounds strange, but I found I can repair a *dead* all in one Jamo unit by using a molex connector from my computer to provide power to the dvd drive inside.
    I would like to start to use the AIO again- Is there any way of using a PSU externally rather than inside a computer, or is there another way of providing +12v and +5v supplies ? :lease:
  2. Mad Mr H
    Mad Mr H
    Jun 10, 2005
    4,460
    London
    +280
    You can buy many different power supplies from places like
    Maplin Electronics and RS Components
    Of course a PC PSU is also fine most I think you will need to work a switch for them to power up/down.
  3. Vandiesel
    Vandiesel
    Jun 6, 2006
    1,470
    +40
    you can bridge a couple of connectors on the atx switch, this will turn it on
  4. mjn
    mjn
    May 24, 2001
    24,299
    Herts, England
    +13,046
    Pin 15 (Green cable) and any ground (black)
  5. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    thanks for the replies guys
    Jamo have offered to replace the aio for £90 since it's £400 new I think for that much I'll take it
    good advice for next time though :smashin:
  6. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Isn't it technically green and grey to activate the unit properly, as opposed to green and ground? Probably doesn't really matter mind - used to use a 400W ATX PSU, car battery and fat ICE system for hall parties at uni - yeah baby!
